cummins injector question?
Old Jan 7, 2012 | 01:13 PM
holset cummins's Avatar
Default cummins injector question?
i am just about to install a set of 150hp nozzles on my truck and i dont know what to torque the nozzles down to. anyone?
Old Jan 7, 2012 | 01:16 PM
lt smoke's Avatar
i believe the nozzels get torqued to 35 ft/lbs on the body of the injector if thats the question you are asking ..if its the whole injector back into the motor then i'm not sure sorry. hope this helps
Old Jan 7, 2012 | 08:47 PM
RAW's Avatar
RAW
If you are referring to the bolts that hold down the injector, they are 10 N·m (89 in. lbs). Those tiny bolts will snap well before 35ft.lbs.
Old Jan 7, 2012 | 08:48 PM
it did. thank you
Old Jan 7, 2012 | 10:30 PM
I hope your having them pop tested before you install them in your truck.
Old Jan 7, 2012 | 11:49 PM
do you know if i would need a boost fooler for my truck. i have heard of defueling but i want to make shure before i buy one?
Old Jan 8, 2012 | 07:56 AM
RAW's Avatar
RAW
What all have you done to your truck?
Old Jan 8, 2012 | 12:57 PM
right now i have an edge ez tuner and a 150 gph rapter with all 1/2" line. i think with the 150 injectors and the chip set on the lowest setting, it shouldnt smoke that bad from a stand still and still have good power
Old Jan 8, 2012 | 12:59 PM
Smoke will also depend on the quality of nozzle. Did you have them pop tested?
Luke
Old Jan 8, 2012 | 01:17 PM
no and i was wondering if i need to have them pop tested or can i get away with not doing it. what is the purpose of a pop test anyways?
and these are the nozzles i am looking at
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Last edited by holset cummins; Jan 8, 2012 at 01:17 PM. Reason: Automerged Doublepost
