Coolant temperature fluctuating
Old Jan 6, 2012 | 11:32 AM
Edahall's Avatar
Default Coolant temperature fluctuating
Vehicle: 1996 Tahoe, 2 door, 4x4, NV4500 transmission
1993 Cummins engine
When I'm driving, the coolant temperature fluctuates from about 180 to 215 on the gauge. It'll go to 215 then about 30 seconds later it'll drop slowly back down to 180 then it'll slowly go back up 30 seconds later to 215. It just keeps cycling back and forth. My other vehicle doesn't do this so what's wrong with it? And yes, the radiator is full of coolant.
Old Jan 6, 2012 | 07:47 PM
sweetv8s10's Avatar
Is an aftermarket guage or a factory guage?
Old Jan 6, 2012 | 08:21 PM
tiremann9669's Avatar
Just your thermostat opening and closing.
Old Jan 6, 2012 | 08:45 PM
BC847's Avatar
^This^
With my mess, it's more pronounced with cold weather. Not a problem.
Old Jan 6, 2012 | 08:54 PM
tower_ofpower's Avatar
Consider yourself lucky, it's a properly working thermostat, I think mine is stuck open. Or it opens and stays open; no in-between
Old Jan 6, 2012 | 11:21 PM
timdale's Avatar
Sounds fairly common for the 12v. Mine does the same. You can get a tstat from cummins that holds a little more steady but takes forever to warm up
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
robbyS
Apr 16, 2015 02:22 PM
97f-250
Nov 23, 2014 08:08 PM
gmcmanis
Nov 9, 2014 04:49 PM
