pillar guage dimmer
Old Jan 6, 2012 | 10:55 AM
gyayo2012's Avatar
Default pillar guage dimmer
any one know what wire to conect to off the harness to run the dimmer for the guages? cant seem to fine it!! 96.2500
Old Jan 6, 2012 | 03:15 PM
Dallas Flywheels's Avatar
I got my pillar gauge light power from the dash light at the cigarette lighter, easy to find.
Old Jan 6, 2012 | 04:20 PM
H.R.D's Avatar
Use a test light or a multimeter to find the correct wire. With dash lights on it should show power then you need to activate the dimmer switch and it should slowly fad to nothing as you move the dial.
Old Jan 6, 2012 | 05:54 PM
Pyro690's Avatar
x2 I can't remember what one it is and I just replaced my headlight switch 2 weeks ago. Oldtimers must be getting to me.
Old Jan 6, 2012 | 10:05 PM
H.R.D's Avatar
I can't either I was searching on the net for a wire guide but no luck in my short search....
Old Jan 7, 2012 | 08:21 AM
gyayo2012's Avatar
ive tryed with the meter but no luck for some reason i cant get any jumps/drops in curnet threw any wire playing with the dimmer, guess im going to have to keep trying then....
Thanksguys!!
Old Jan 7, 2012 | 08:26 AM
RAW's Avatar
RAW
Not sure if irs the same or not, but here is where it can be found on a '01
https://www.dieselbombers.com/dodge-...mer-power.html
Old Jan 12, 2012 | 01:05 AM
Xraytheo's Avatar
orange wire in the gray plug into your radio should be the dimmer if you wanted to tap into it there. turn your markers on and check it with a test light by dimming the dash. dont use those stupid scotch connecters that peirce the wire to splice either. i wouldnt even use those on a Lada! solder and shrink tube, or un insulated crimp connector, solder, and shrink tube only ways to go! you can drive your truck under water and that splice will hold! (cant say the same for anything else tho)
pwerstrokekid
Mar 29, 2015 11:28 PM
