P0243 Fault Help
Old Jan 5, 2012 | 08:20 PM
04.5 FarminCummins's Avatar
Default P0243 Fault Help
Hey has anyone had any experience with the P0243 Code? It's a Turbocharger waste gate malfunction A code definition. I've got the stock Turbo no motor mods besides an intake/intake elbow. Dealership has been no help and i can't find and info online. Just joined looking for help and more info on future mods.
Oh and the boost is down to around 22 pounds when it was running 30-35 before the fault. Also running a Smarty S-06 Tuner
Last edited by 04.5 FarminCummins; Jan 5, 2012 at 08:20 PM. Reason: Automerged Doublepost
Old Jan 5, 2012 | 08:42 PM
wildbill's Avatar
Sounds like the wastegate solenoid is at fault.
Old Jan 5, 2012 | 08:45 PM
Is there any way to check that besides replacing the solenoid?
Old Jan 5, 2012 | 09:00 PM
wildbill's Avatar
Turn the Ignition on, engine not running.
Disconnect the Wastegate Solenoid harness connector.
Connect an incandescent test light across the supply and driver pins at
NOTE: The ECM will perform a self check of the circuit after
approximately 30 seconds, which should light the incandescent
test light.
Does the light illuminate brightly after 30 seconds of being
connected?
Yes >> Replace the Wastegate Solenoid.
Perform POWERTRAIN VERIFICATION TEST VER - 1
(DIESEL). (Refer to 8 - ELECTRICAL/ELECTRONIC CONTROL
MODULES/ENGINE CONTROL MODULE - DIAGNOSIS
AND TESTING)
Old Jan 8, 2012 | 02:18 PM
Thanks bill. Haven't been on in a few days to get this but i'll give it a whirl. Would you know where i could find the powertrain verification test info?
Old Jan 8, 2012 | 02:38 PM
wildbill's Avatar
If you know of someone that has a Chrysler Star Scan.
Old Jan 8, 2012 | 07:56 PM
Nobody besides the dealership.
Old Jan 8, 2012 | 09:03 PM
wildbill's Avatar
I'm not sure if you got a Cummins shop near ya, but I'm pretty sure they got the solenoid (Holset is a Cummins subsidiary). Cheaper than the dealer no less.
Old Jan 8, 2012 | 09:49 PM
I'll definately look into that.
