Loss of top end with fuel plate movement
Old Jan 4, 2012 | 11:45 AM
smokedout's Avatar
Default Loss of top end with fuel plate movement
buddys 94 was a auto now swapped with 5 spd. he had a #100 plate in it in stock location and he truck would get pass 95 easy now that i moved it forward the truck is quicker but it hard for it to even get to 90. why would this be?
Old Jan 4, 2012 | 12:01 PM
MillerBoyzDiesel's Avatar
did he change out his turbo?
Old Jan 4, 2012 | 12:16 PM
turbo2332's Avatar
before or after tranny swap?
Old Jan 4, 2012 | 01:05 PM
id say if its stock turbo for auto truck on there hes got alot more drive press. than he used to have.
Old Jan 4, 2012 | 01:34 PM
turbo2332's Avatar
its the same turbo it will be a WH1C. autos are faster its no argument. i dont know final drives as this may be what you are experiencing?
Old Jan 4, 2012 | 02:33 PM
smokedout's Avatar
both the 95mph and hard to get to 90mph was after everything else was done and yes the stock turbo is still on there.
Old Jan 4, 2012 | 03:54 PM
turbo2332's Avatar
same boost #'s is your fuel pressure up to snuff?
Old Jan 4, 2012 | 07:45 PM
smokedout's Avatar
No gauges,,this was all in a 45 min time period
Old Jan 4, 2012 | 07:56 PM
turbo2332's Avatar
move it back to the stock location. see if it changes it again? when you took the AFC off did you crack or break the reference line? may be leaking boost? gotta find the bugs. things dont generally JUST happen. retrace what you did.
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
SMatyac
Nov 15, 2014 07:35 PM
