1993 cummins problem
Old Jan 4, 2012 | 09:49 AM
michael 5.9's Avatar
Default 1993 cummins problem
my 12v has been smoking white and i dont know what it is. when ever i start it, it smokes black, but when i rev it, it smokes white. also when i start it it will have a weak start and other times it with have a strong start. the truck is stock except for a cold air intake and the fuel pin has been turned. do you guys know what the problem might be?
Old Jan 4, 2012 | 02:27 PM
1arock's Avatar
White smoke is usually unburned fuel. You may have a bad injector that is leaking off that also would explain the weak startup. How does it run otherwise has the fuel milage or power fell off badly? Rocky
Old Jan 4, 2012 | 02:51 PM
jdbigblue12v's Avatar
on a very cold start without grids working, why does my truck smoke pure blue??
has no blow by at all either
Old Jan 4, 2012 | 03:38 PM
ive lost 6mpg and i have noticed a good size power loss
Old Jan 5, 2012 | 04:43 PM
1arock's Avatar
I gonna bet you have at least 1 injector bad. In my part of the world pump shops will test them for free. If one is really hoseing bad it can wash that cylinder down and lead to bigger problems, better check it out pretty quick.Rocky
Old Jan 5, 2012 | 05:06 PM
as soon as i get the money for new injectors ill get them all done. and put bigger injectors in. im only a week away from getting them
Old Aug 1, 2012 | 02:37 PM
93DodgeDiesel's Avatar
Maybe burnin oil or a bad injector!!!
burndiesel
10
Feb 7, 2023 01:15 AM
Antwhite19
Mar 26, 2020 04:58 PM
jeremy01995
Sep 14, 2015 06:34 PM
old chevy
Sep 2, 2015 08:42 AM
signoremint
13
Oct 21, 2014 07:21 PM
