NV5600 input shaft
Old Jan 2, 2012 | 09:58 PM
haulitrite's Avatar
Default NV5600 input shaft
I removed my trans today to replace the front seal on trans. What I found was more than I planned on.
The pilot bearing in the flywheel was in a thousand pieces laying on the bell housing. Causing the input shaft to slap around in the front bearing retainer (input shaft cover) and chewing up the shaft (see picture). The shaft also has ~ 1/4'' of play side to side (see picture). Is a rebuild necessary or is this considered acceptable.
Where should I go from here.
Thanks,
If you have any questions please ask
Attached Thumbnails NV5600 input shaft-nv5600-006.jpg   NV5600 input shaft-nv5600-005.jpg
Old Jan 4, 2012 | 07:05 AM
steved's Avatar
It actually looks like the input shaft is twisted at the splines?
Old Jan 4, 2012 | 10:07 AM
haulitrite's Avatar
The splines are straight. Just the way the picture was taken I guess.
Old Jan 4, 2012 | 11:17 AM
MillerBoyzDiesel's Avatar
id say your input shaft bearing and pocket bearing need replaced and then reset the endplay on both shafts. the input shaft bearing supports the input shaft, so it wont be rocking up and down and left to right when the trans is installed but you dont want alot of play at the input shaft. You might could get away with just reshimming it for awhile but id replace bearings while I had it out.
morris360
Aug 5, 2015 09:25 AM
boostkid
Jun 3, 2015 11:17 AM
dpgcummins12v
12
Apr 20, 2015 10:24 PM
SixSpeed
Jan 11, 2015 01:41 AM
woodsman27
Dec 9, 2014 09:55 AM
