Cp3 upgrade
Old Jan 2, 2012 | 04:20 PM
6spd's Avatar
Default Cp3 upgrade
Will a arson competition kit fuel f1 flux 4 or 5 injectors
Old Jan 2, 2012 | 05:40 PM
colesparts's Avatar
ask buddy at wicked diesels ,,with the mods you have you may want to send him your cp3 and get it built....jmo
Old Jan 3, 2012 | 08:59 AM
MillerBoyzDiesel's Avatar
better get duals, arson kit wont keep up and even a single 85% pump wont keep your r.p. up with 200 horse injectors
Old Jan 3, 2012 | 09:11 AM
6spd's Avatar
Ya thats what i was thinking, just tryin to budget things i was thinking if i could get away with a big single for a little bit then upgrade to dual later
Old Jan 3, 2012 | 09:33 AM
What Turbo are you going to run with 200s?
Luke
Old Jan 3, 2012 | 10:57 AM
I had the same idea but the 85% cp3 couldnt keep up even with a mp8 cranked up. 5th and 6th at wot would pull rail press. down bad. I used to hate the idea of duals, wanted a single to keep things appearing stock but, duals were the only answer. The setup I run now lets me keep r.p. setting on smarty at stock level. Its nice not having a crazy ramp rate. I dont worry about cracked injector bodies like I used to.
Old Jan 3, 2012 | 07:31 PM
tyler00's Avatar
The arson comp kit is not for DDing either.
Old Jan 4, 2012 | 10:18 AM
6spd's Avatar
I currently have a super phat shaft 66, what turbo would you recommend? it wont get driven much on the street just maybe once a week or so, mainly want to pull
Old Jan 4, 2012 | 11:06 AM
id stick with the 66 or at least a version of it. 2.6 class is expensive, id hate to know how much money it takes to be competitive in a 3.0 or unlimited class
Old Jan 5, 2012 | 06:28 PM
6spd's Avatar
thats what i was planning on doing, i can get 60lbs of boost with it it just does not spool good but with injectors other mods it will light quicker
