pot or switch?
Old Jan 2, 2012 | 09:49 AM
sinwagon's Avatar
Default pot or switch?
ok just checked the tps on this by one of the threads i found and the voltage is no where close and i couldn't get it adjusted. is shifts to OD just fine and at a range i expect it to but it won't stay locked up i already have the stuff for the lock up switch and thanks to posts on here i know hoe to set up the 47RH.
Old Jan 2, 2012 | 11:37 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
did you drill the holes out bigger to see if that helps. this is a big problem on these trucks.
Old Jan 2, 2012 | 12:24 PM
sinwagon's Avatar
talking about the mount holes for the tps?
Old Jan 2, 2012 | 02:04 PM
diesel pap's Avatar
yes that will allow a little more adj.
Old Jan 2, 2012 | 06:00 PM
mysterync's Avatar
Usually you can install a new bell crank and bushings and fix it. You can do a tps delete but that leaves you with binding or tight throttle linkage.
Sent from my DROID BIONIC using Tapatalk
Old Jan 2, 2012 | 06:46 PM
sinwagon's Avatar
after looking at how much play there was before the tps started moving i decided to put the lockup switch on for now will probably put the pot on later
cumminspwr11
12
Oct 17, 2021 03:50 AM
rstrange1996
Sep 22, 2015 01:25 PM
Ryans71
Diesel Engine Conversions
Dec 24, 2014 08:47 AM
IslanderXJ
Dec 17, 2014 04:14 PM
7.3lfordguy
8
Oct 17, 2014 11:45 PM
