Injector cups
Old Jan 1, 2012 | 01:08 PM
sutie's Avatar
Default Injector cups
How long and difficult will it be to replace the injector cups? I'm under the assumption that 1 or more is leaking coolant and pushing it through the lower valve cover...anyone ever heard of this?
Sent from my HTC Liberty using Tapatalk
Old Jan 4, 2012 | 03:20 PM
fox2boost's Avatar
The same time involved for changing injectors
I would check balance rates first so if you have one or two injectors going south you can kill two birds with one stone.
fox2boost's Avatar
If you've done it before 8-11 hours depending if you have egr or not.
Old Jan 4, 2012 | 03:21 PM
fox2boost's Avatar
Took me most of a weekend my first time.
Old Jan 4, 2012 | 03:59 PM
MillerBoyzDiesel's Avatar
should take 4-6 hours, what makes you think the cups are leaking?
Old Jan 4, 2012 | 04:45 PM
Farmboy 2.0's Avatar
Do you get fuel in your oil? And in the cooling system? You should also have some what sweet smelling white smoke if they are bad enough. And im with fox2boost. i would make sure the injectors test out well before you do the cups to kill 2 birds at once. And if they test out good then you can get new cups and use a merchant install kit like this one below.
Merchant Automotive 10058 - 01-04 GM LB7 DuramaxLB7 Injector Install Kit
Old Jan 5, 2012 | 10:26 PM
sutie's Avatar
Injectors are all good, I got them replaced about 6 months ago. I'm thinkingn that one of the cups isn't seated right now and its causing coolant to leak. Just recently I noticed a little by the egr cooler, so I think I'm gonna block off or remove the cooler completely and see if this fixes it. Any suggestions???
Sent from my AT100 using Tapatalk
Old Jan 7, 2012 | 01:38 AM
fox2boost's Avatar
I would really like to see you torque everything correctly and have it back together in 4-6 hours.
Old Jan 10, 2012 | 10:31 AM
well stop by sometime and ill show ya
Old Jan 10, 2012 | 04:19 PM
fox2boost's Avatar
Keep typing.
