How to Instal 3200 rpm gov spring in VE pump?
Old Jan 1, 2012 | 09:05 AM
Cummins12Club's Avatar
Default How to Instal 3200 rpm gov spring in VE pump?
I was wondering if anyone could give me instructions as to how to instal the gov spring in my rotary pump. i have already installed a denny t stage two fuel pin and now need to install my gov spring. pictures would be nice as well as to where its located, thanks
Old Jan 1, 2012 | 09:45 AM
Gots_a_sol's Avatar
Den - Dodge CTD 1st Gen - VE Governor Spring Install
My only suggestion is when you get to the part where you need to hook the spring to the shaft, push the shaft out of the pump top, hook the spring to it, then put the shaft back in the pump top. Doing it that way will save so much frustration and and will avoid the potential loss of the top hat and its spring.
Old Jan 1, 2012 | 11:14 AM
RSWORDS's Avatar
A flat head screw driver will wedge the hat in place also.
Old Jan 2, 2012 | 09:12 PM
ok but where is the spring located
Old Jan 2, 2012 | 09:40 PM
big bad diesel 416's Avatar
Site Sponsor
its under the AFC housing the big 4 bolt thing on the top of the pump
look here for how too's https://www.dieselbombers.com/1st-ge...en-sticky.html
and heres the spring
VE44 '366' spring installation - 1st gen - Dodge Ram, Ramcharger, Cummins, Jeep, Durango, Power Wagon, Trailduster, all Mopar Truck & SUV Owners.
Old Jan 4, 2012 | 07:30 PM
Thanks for your help big bad! there was a ton of info on that page, i printed out a ton of info just on VE pumps, thanks!
Old Jan 4, 2012 | 10:35 PM
Site Sponsor
your welcome bud!
Old Jan 5, 2012 | 08:42 PM
You wouldnt happen to work at or own bigbaddiesel.com would you?
HardLuck
Jun 24, 2015 08:04 AM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
frankenstein1313
Sep 28, 2014 02:24 AM
