BIG PROBLEM
Old Jan 1, 2012 | 03:21 AM
jdbigblue12v's Avatar
Default BIG PROBLEM
was driving truck tonight and hit a bump thats when my fuse panel under dash fell down, arked against brake pedal on bottom left butt connector, and shut the truck off. i tried to recrank it but had no luck. i have cab lights that are added on and put that against one of the copper tabs under fuse spots and it cranked but had to stay connected to the metal. i tried to shut truck off by key and didnt work til i pulled off the cab light wire. no blown fuses, no bad fusable links that i could see. honestly dont know where to begin looking to see what had happend or what is the actual problem. thanks in advance for anyone who has an idea.
Old Jan 1, 2012 | 08:21 AM
NadirPoint's Avatar
I'd be willing to bet there's a fusible link gone. Jump 12v to the shutdown solenoid to get it running temporarily while you look for the electrical problem.
Old Jan 1, 2012 | 11:02 AM
sweetv8s10's Avatar
So do u not have power to your ignition at all?If not then it probably burnt the orange fuseable link closest to the engine mine was burnt into and u couldnt even tell.
Old Jan 1, 2012 | 11:34 AM
NadirPoint's Avatar
Originally Posted by sweetv8s10
S... probably burnt the orange fuseable link closest to the engine ...
That being the case, then it's really a relatively small problem!
Old Jan 1, 2012 | 02:34 PM
haha small problem.... there is no power going to the ignition unless i touch the cab light wire to copper contact under the 3 fuses on the left
so played with it again just now and it seems like the last 3 fuses need to be grounded now and i will need to install an ignition kill switch?
Last edited by jdbigblue12v; Jan 1, 2012 at 02:34 PM. Reason: Automerged Doublepost
Old Jan 1, 2012 | 02:56 PM
sweetv8s10's Avatar
I would cut out the orange fuseable link and replace it with a 40 amp circuit breaker and see if that fixes your problem but thats just my opinion and that was the exact same problem I had with mine.
Old Jan 1, 2012 | 03:13 PM
NadirPoint's Avatar
If that was a question, I will have to respectfully decline to attempt an answer.
Old Jan 1, 2012 | 04:48 PM
just got back in gave up on it gonna sell the truck and get something newer sick of these 1st gen wiring problems. the problem is that the truck needs to be grouned from its own fuse panel. when i do that it runs until i remove the wire from the underneath of the fuse panel. if i start the truck hold wire on to run i can remove the key from the truck and it still runs. i cant afford to take it to a shop for repairs, dont know how to rewire an ignition, and dont know of anyone in the area with a 1st gen that knows how to work on this truck.
Old Jan 1, 2012 | 05:16 PM
NadirPoint's Avatar
...the truck needs to be grouned from its own fuse panel.
You do realize that is a contradiction in terms right? Grounding fuses?
Have you checked continuity on the fusible links? Myself and another poster here have both told you that is most likely the problem. You cannot visually verify their integrity.
Otherwise, I'll give you $200 for it.
OBTW, I forgot to mention, what initially started your problem, grounding the fusebox on the brake pedal was YOUR fault, not "1st Gen wiring problems."
Old Jan 1, 2012 | 06:13 PM
ok first off this isnt the first wiring problem i had and yes it was my fault because i bought one of these are shitty garbage made trucks id rather junk it than give someone else the problems of it. i checked everysingle fuseable link with a voltmeter and none are bad
