water meth injection????????
Old Dec 31, 2011 | 08:16 PM
tmonroe's Avatar
Default water meth injection????????
Is water meth injection reAlly that good or is it in needed ??
Old Dec 31, 2011 | 09:39 PM
monster12valve's Avatar
nice for towing, adds HP and lowers egt quite a bit
Old Jan 1, 2012 | 12:32 PM
colesparts's Avatar
im not a big fan of any of this stuff going in any of my engines...like your throwing moisture in your engine...
im sure some people dont mind if your continously towing thats fine ,,but if you are a daily driver and say you sit for along period of time ..thats bad cause you havent burned all the moisture out if it even does...? jmo
Old Jan 2, 2012 | 08:57 PM
tower_ofpower's Avatar
Not meant to be injected with no load, most kits come with boost activated switches to prevent injection until a set psi or progressive rate controllers.
Old Jan 3, 2012 | 06:28 AM
whitelightning19's Avatar
I have Snow stage 3 kit and love it. It helped drop egt's a bunch while pulling and added hp too. Just got to make sure you dont shhut the truck down right after you injected water. If i run mine i always let it sit 5 min or cut it off a few miles from the house just to let all the water get out.
Old Jan 3, 2012 | 07:00 AM
NadirPoint's Avatar
W/M injection has bee used to great effect in all sorts of engines for over 70 years. You'd think if there was any problems with it they'd have surfaced by now.
Oh, and don't forget the one about how it might rust out your engnie from the inside!
Originally Posted by colesparts
...say you sit for along period of time ..thats bad cause you havent burned all the moisture out if it even does...? jmo
An uninformed opinion it would be. Exactly how long do you think a fine mist of diluted alcohol will last before it evaporates inside a hot intake anyway? Even not running?
Cougdiesel
Feb 2, 2016 10:17 AM
Aug 27, 2015 04:00 PM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
yams
Dec 7, 2014 12:51 PM
