s366 yes or no?
Old Dec 31, 2011 | 02:28 PM
empty wallet's Avatar
Default s366 yes or no?
Heres the specs:
BorgWarner S300-SX3 (aka S366 or S300 91-79)
Compressor
Housing: 4.00" Ported Anti-Surge inlet with 3.00" charge pipe outlet
Inducer: 66mm
Exducer: 91.4mm (Extended Tip Technology)
Turbine
Housing: .91 A/R Twin Scroll
Inducer: 73mm
Exducer: 80mm
I'll be adding an edge comp to the setup in my sig when I do the turbo, as well as some kind of exhaust manifold upgrade, BD 3 piece or ATS, not sure... opinions?
I'm thinking if ANYTHING my 150's won't fuel hard enough to light that bad boy, but for the time being I'm dead set on a big single setup... maybe throw some 200 or 220 nozzles on my stockers when I can?
Last edited by empty wallet; Dec 31, 2011 at 02:28 PM. Reason: Automerged Doublepost
Old Dec 31, 2011 | 10:12 PM
Red_Rattler's Avatar
High Tech Redneck
Id run it and yes more fuel will help you get it lit quicker
Old Dec 31, 2011 | 11:48 PM
globalwarmingcontributor's Avatar
Does that turbo bolt right up, no mods needed? I'm in the market for new turbo...keeping my options open, I am looking at 62mm turbo from industrial injection
Old Jan 1, 2012 | 05:17 PM
It's a T4 flange so no... but a 66mm would be way too big for you, like I said above I'll change up to 200 nozzles if I need to with it, plus I'm going to aftermarket manifold...
Old Jan 1, 2012 | 09:37 PM
im planning on 150hp nozzles and bigger hot rod vp. would it still be too big?
Old Jan 2, 2012 | 08:42 AM
1st_gen_puller's Avatar
The hot rod vp isn't an upgrade.... you will get better power out of a SO pump..
Old Jan 5, 2012 | 06:31 AM
so is this a good turbocharger? ive got plans for bigger injectors....throwing an edge comp on there soon. got an fass 95 pump. do they make t3 to t4 flanges??
Old Jan 5, 2012 | 07:51 AM
High Tech Redneck
Stick with a 62
Old Jan 5, 2012 | 10:48 AM
01quadcab's Avatar
a 66 isn't ideal for a daily driver. Some people do it, but you have to drive truck a lot more by sight to make sure your not just smoking everything out
Old Jan 5, 2012 | 11:57 AM
Farmboy 2.0's Avatar
Even with a Edge Comp and 200's that turbo will be laggy. If you did a cam as well that would help spool up time as well. I have injectors close to a 300hp range and I run a silver 64. A 66 is a hard turbo to run and spool and daily drive on a VP truck IMO
