synthetic or regular oil?
Old Dec 30, 2011 | 03:06 PM
starrysky111's Avatar
Default synthetic or regular oil?
ok guys was getting ready to change my oil and have allways been a fan of synthetic oil mainly because of the increase fuel mileage you get. is it worth it or not its about a $45 dollar difference.
is it worth going synthetic in the transmission and transfercase and rear end also.
had a ford lightning once and converted all rolling parts to synthetic and gained 3 mpg. hence the questions.
Last edited by starrysky111; Dec 30, 2011 at 03:06 PM. Reason: Automerged Doublepost
Old Jan 4, 2012 | 10:35 AM
Heath's Avatar
Authorized Amsoil Dealer
It's been a few days and no response, so I'll pipe in
I too am a fan of synthetics for many reasons but lets address the one you mention..fuel economy.
A gain in fuel mileage has many variables but in general, using a syn can help improve it. Data will show that most of the gain comes from using a syn in the drive train..tranny and diffs, but you can get some from engine oil as well.
So if mpg is the goal, then it should be used throughout as you have done in the past.
As for cost difference, it all depends on which oil you want to use and how you want to use it. One could actually save money in the long run.....
Old Jan 4, 2012 | 11:41 AM
Rooster24v's Avatar
you wont go wrong either way, Synthetic is a better oil, however your motor wont complain using non synthetic oil as well. I was using Rotella 15w40 in my cummins, i switched to Synthetic Rotella 5w40 and it seems to start better in the colder temps. but that is the weight of oil i am using. I prefer 5w than 15w anyway.
Old Jan 4, 2012 | 11:52 AM
rufushusky's Avatar
The one and only oil I ever ran and noticed a change in MPG was JD 0W40 in my cummins...gained maybe .5mpg over 7500 miles. I have run a host of oils, conventional, blends and synthetics, from amsoil to rotella, delo, valvoline, castrol etc etc and never noticed any difference in mpg in either my dodge or my ford. If I still owned a Cummins it would get nothing but a 15w40 all year in New England. It was a great cold weather engine.
Old Jan 4, 2012 | 05:03 PM
globalwarmingcontributor's Avatar
Default synthetic oil
Ill be hitting your website in the next month to get 5w-40 oil and a good filter. if i remember right my 2002 24v cummins takes 11 quarts with filter??? question, you offer military discounts? pm me. Thanks bud
Old Jan 5, 2012 | 12:01 AM
diesel life's Avatar
i personally run shell rotella 15w-40 in my 2001 have been since i got the truck never had a problem with it cold or warm weather thats what the dodge dealer that i bought it from recomended i have thought about switching over but cant complain about the rotella just my.02
Old Jan 5, 2012 | 08:45 AM
Heath's Avatar
Correct on the amount. As for pricing(that goes for anyone) don't order til you contact me. Don't want anyone paying more than they have to
Old Jan 5, 2012 | 10:55 AM
01quadcab's Avatar
Run synthetic in it it will start better and idle quieter. My neighbors all noticed when I swapped mine over. Your biggest gain in the dodge is changing the gear oil in the front and rear end over. The transfercase should already have synthetic atf+4. The trans also should of come with a synthetic. What is the mileage on the truck and have you serviced the trans yet?
Durtyd09
Nov 11, 2015 01:43 PM
1stgenSWB
Aug 13, 2015 12:19 AM
soco
Jul 27, 2015 06:06 PM
sjslhill
Jul 22, 2015 01:02 PM
coors_man_2005
Dec 15, 2014 10:23 AM
