Charging System Issue
Old Dec 29, 2011 | 05:51 PM
wildbill's Avatar
Default Charging System Issue
OK, my volt meter stays around 8 volts (grid heater relay kicks out). So I take it down to Carquest, and his meter shows I'm overcharging (had his meter on the pass side batt). No codes, no CEL, alternator was new early this year.
So with that in mind: bad alternator, bad battery, bad regulator (ECM)??
Old Dec 29, 2011 | 05:58 PM
wildbill's Avatar
This is why I got a good relationship with my dealer. Said the cable between the two batteries is crapped out. Volt meter reads off the drivers side batt, while the pass side gets overcharged (went through 3 sets of batt's cause the pass side got cooked).
Old Dec 29, 2011 | 06:02 PM
H.R.D's Avatar
So the cable was the problem. Interesting how did they pin point that one?
Old Dec 29, 2011 | 07:24 PM
wildbill's Avatar
They must be a common issue. I should've known something was wrong after my stock pass side battery only lasted a year and a half.
Old Dec 29, 2011 | 08:41 PM
H.R.D's Avatar
I got ya.
JoeyMiR
9
Feb 3, 2018 10:05 PM
Adell Bob
Mar 23, 2015 12:39 AM
Jreeb
Oct 20, 2014 01:31 PM
hemiheath
Oct 15, 2014 11:49 AM
Mopar Mike
Oct 6, 2014 07:51 PM
