2 wheel to 4 wheel
Old Dec 29, 2011 | 05:02 PM
adub12valve's Avatar
Default 2 wheel to 4 wheel
Ello all. What all would I need to convert a 2 wheel drive manual tranny to 4 wheel drive?
Old Dec 29, 2011 | 08:46 PM
12v15004x4's Avatar
4wd main shaft, lock ring pliers, main shaft bearing, dial indicator to measure main shaft bearing preload, 5th gear nut and socket, torque wrench 250ftlbs, 4wd output cover, 29 spline transfer case.
Old Dec 30, 2011 | 12:16 PM
Why would I need a 5th gear nut when its a 5 speed?
Old Dec 30, 2011 | 03:56 PM
12v15004x4's Avatar
The 5th gear nut is recommened one time use only.
Old Dec 30, 2011 | 05:03 PM
Ok you are saying replace it in otherwords? And would I be better off looking for a 4 wheel drive?
Old Dec 30, 2011 | 11:04 PM
12v15004x4's Avatar
Yes replace it, I also mention the main shaft bearing for replacement. How much did you get the 2wd nv4500? Due to them having a main shaft problems, I would just get a main shaft for yours and then you know its brand new. But you still need the output cover
Old Dec 31, 2011 | 03:25 PM
Ok, well the guy wanted 1000 for it. It comes with everything to convert it he said. I just didn't know if it would be worth it
cutthroatxxx
Jun 22, 2015 10:16 PM
6.5dieselman
Feb 26, 2015 04:45 PM
FELTONMICHAEL
Dec 28, 2014 01:09 PM
NiNjAassasin545
Dec 2, 2014 11:40 PM
94ifs
For Sale
Oct 23, 2014 01:35 PM
