Need Fuel
Old Dec 29, 2011 | 12:02 PM
IHdude's Avatar
Default Need Fuel
I have a 96 that im not getting any fuel to the engine with. checked it by cracking the line over the injector and then over the pump. was told its either the solenoid, a fuse, or the pump inside the tank. i was wondering how you would check to see if the solenoid is working or not? any help is much appreciated
Old Dec 29, 2011 | 07:03 PM
captain_stabbin's Avatar
when you turn the key to start engine, this is when the solenoid engages, bump the starter an leave key on an go pull up an see if solenoid is up or not.
as far as pump in tank, no, lift pump is on the block
Old Dec 30, 2011 | 04:00 AM
IHdude's Avatar
what exactly is it im looking for to pop up on the pump, i was told the solenoid is on the back side of the pump but what should be the difference from key off to on after bumping the starter?
Old Jan 8, 2012 | 05:13 PM
mudball_79's Avatar
The reason you have to bump the engine over is because the solenoid is a two stage setup, stage 1 activates the strong magnetic field to open the fuel valve, stage 1 is only powered while in "cranking" or "starting" position, stage 2 is a lower field designed to hold the valve open while in "run" mode. If you don't crank first,and just turn on the key, stage 1 is not used therefore the solenoid is not opened for stage 2 to hold it.
To test stage 1&2: Crank engine over,without shutting off ignition, check that solenoid plunger is up
To test stage 2 only: Turn on ignition,without cranking, lift solenoid plunger by hand, if it stays up stage 2 is working
The solenoid is located on back of pump on the side away from engine, find the 3 wire plug above the rear of pump follow it to the solenoid
Old Jan 9, 2012 | 12:35 PM
turbo2332's Avatar
it is easily visable. prolly 1.5 to 2 inch around and about 2 inches long, when viewed from the top. it has a rod coming out of the bottom of it which is connected to the linkage they are talking about. you pull this linkage up (or check that it is up). there is a little blue wire that goes to the driver side battery + wire. it corrodes often. if it is you will have a no start problem.
Old Jan 9, 2012 | 08:23 PM
IHdude's Avatar
checked to see if the rod would push up when key is turned and it wouldn't budge. wasn't coming up either when trying to start. is the solenoid locked or is something else holding it from moving at all? thanks for all the help!!
Old Jan 9, 2012 | 08:29 PM
turbo2332's Avatar
disconect the cylonoid from the arm. then manually hold the lever up whule a buddy attempts to start the truck. see if she goes.
Old Jan 9, 2012 | 09:29 PM
mysterync's Avatar
If you just take the solenoid off it will start. No need to hold it up.
Sent from my DROID BIONIC using Tapatalk
Old Jan 9, 2012 | 10:42 PM
IHdude's Avatar
Thanks for the input, me and a buddy were actually talkin about trying that. We'll see how she goes. Thanks again!
Old Jan 10, 2012 | 10:37 PM
Heavyhaul07's Avatar
So any news
