cleaning injectors
Old Dec 29, 2011 | 11:14 AM
Summers5.9's Avatar
Default cleaning injectors
What's the best way to clean your injectors
Old Dec 29, 2011 | 11:28 AM
white93's Avatar
Some kind of diesel treatment or give the truck a good work out. Your injectors shouldn't be dirty unless you ran something other than diesel, like oil.
Old Jan 11, 2012 | 03:40 PM
Seydler3's Avatar
Throw like a quart of tranny fluid in your tank.
Sent from my Droid
Incredible 2 by HTC via Tapatalk.
Old Jan 11, 2012 | 09:06 PM
torqctd's Avatar
Sent from my Droid
Ignorant statement.......do not use ATF......it does not burn completely......use an additive made for diesels
Old Jan 11, 2012 | 10:04 PM
Seydler3's Avatar
You're right. I only put it in my tank every couple weeks and it seems to work great. Now I do not know about using ATF with a Common Rail or HEUI Powerstroke but it seems to do fine with rotary pump trucks. Use some Diesel Kleen or even a bit of biodiesel.
Sent from my Droid
Old Jan 13, 2012 | 03:35 PM
06Dodge's Avatar
ATF shouldn't be used in any HPCR fuel system its hard on the injectors.
Old Jan 13, 2012 | 04:49 PM
Seydler3's Avatar
Like I said I'm not sure about using it on common rails.
Sent from my Droid
Old Jan 14, 2012 | 02:54 PM
steved's Avatar
Sent from my Droid
You posted the response in a common rail forum??
To the OP, a dose of fuel additive in the interim, or have them pulled and checked by someone like Formula 1.
Old Jan 14, 2012 | 03:11 PM
fox2boost's Avatar
I use stanadyne I have heard of people adding 2 stroke oil on fill ups as well.
I just put new injectors so I'm not taking any chances with something I put in my wead wacker though.
Old Jan 14, 2012 | 04:03 PM
Seydler3's Avatar
Sorry...the app I'm using had this thread under "Latest" so I didn't know what kind of truck he was talking about.
Sent from my Droid
