Soot???
Old Dec 28, 2011 | 07:34 PM
beast6.5's Avatar
Default Soot???
I have a 94 2500 auto, if a 160 pump has a 100 plate in it and slide all the way forward should it soot? Im not trying to soot on purpose i just was "testing" to make sure everything on the pump end of the engine was normal. I ask this because i made a 100 plate slide it all the way forward all i get is a puff of smoke off the line and thats it.
Old Dec 28, 2011 | 07:43 PM
turbo2332's Avatar
yep thats about it. if the fuel plate is your first mod as it was mine you are or should be quite disapointed. your engine cant rev high/fuel hard enough to give you -real- noticable gains. you do gain but not like all the hype make you believe. if you want a much more responsive truck install 3 or 4k govoner springs. hands down the best modification to a 12 valve cummins!!! it will be a totally different truck. and keep the 100 plate.
Old Dec 28, 2011 | 07:50 PM
beast6.5's Avatar
Thanks, Im looking at getting DVs and 7 hole .10 injectors next. Springs, 4k gsk, spilt horn intake and twins later down the road. and of course a TC and shift kit will have to come before all.
With a manual valve body do you control all 4 gears??
Old Dec 28, 2011 | 08:20 PM
turbo2332's Avatar
dont do DV's or injectors that big till you have a good set of twins in your hands. the truck will be WAY HOT! and prolly bout unusable. 5x.012 or.014 are plenty for a DD truck and can get you well into the 500-600 HP range.
and yes but i wouldnt recomend one on a DD. you will wear you shift linkage quickly and get very tired of shifting it. IF you do you that rough get a reverse manual VB so if you mess up you dont throw the truck into N or R and DESTROY lots of expensive things. my vote is not to do a manual VB unless you drag, pull, or mud race as that was a WONDERFUL advantage in the big holes back in the day.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
duramaxtuner
Chevy/GMC Duramax 2011 LML
Jan 26, 2015 11:14 AM
