no heat little tiny bit out defroster
Old Dec 28, 2011 | 07:51 AM
diesleguy's Avatar
Default no heat little tiny bit out defroster
hey guys so i get no air out any of the vents on any setting only a little bit out the defroster. ive bein reading and desided that theres a vaccum line behind the passenger side dash that has come off witch controlls the doors for diffrent settings? also the blower motor only runs on the two high settings. is this a resistor pack issue? what is a resistor pack and what does it do? if theses are the problems i will replace blower motor and resistor pack. am i missing something? are there tips and tricks to making this go smoothly?
there is heat in the radiator line and my engine temps are normal
please and thanks
Old Dec 28, 2011 | 09:18 PM
gyayo2012's Avatar
i had the same problem with y jeep cherokees i know its not a truck but its a crysler product and imo its all the same ****! they had a problem with blowing the control pannel use to blow a couple of them every year if i were you i would try there first!
Old Dec 30, 2011 | 02:29 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Your correct about the blower motor running on high. Thats definitely your resistor
auspot
Jun 30, 2015 05:57 AM
