Clutch master cylinder bleeding
Old Dec 27, 2011 | 03:34 PM
Cody Cummins's Avatar
Default Clutch master cylinder bleeding
Recently i had to replace my clutch master cylinder since the guy i bought it from jerry rigged it, i got one from advanced autoparts for my valair dual disk clutch and i cant seem to get this thing to bleed, can yall give me some direction? Thanks
Sent from my PG86100 using Tapatalk
Old Dec 28, 2011 | 03:11 PM
Bump?
Old Dec 28, 2011 | 04:02 PM
dukeboy_318's Avatar
These things are dang near impossible to bleed in the truck. Matter of fact, they aren't designed to be hand bled and do not have a bleeder valve. You are actually supposed to buy the whole thing, master+ slave which are normally pre-bred by a machine.
Now it can be done. I've replaced several and about the only way you can bleed these things it to remove the master and slave both from truck When removing the slave, be very careful not to shoot the push rod out of the slave.
From here on, you will need 2 people for this, counting yourself, brake fluid, a small 4in block of wood and a vise and rags. One it is out, make sure the line from the master to the slave is connected, put slave gently in vise, have one person hold the block of wood to the pushrod of the slave cyl and with the other hand, they need to hold the master cylinder level above, fill master cylinder with brake fluid, now go and work the master cylinder actuator, as you push, the other person should apply gentle resistance to the slave pushrod while allowing it to move( they can use the block of wood to push against as it is more comfortable on the hands but its not required), once you have it depressed all the way, make sure master cylinder is full of brake fluid, then have the other person push the push rod back in as you apply resistance on the master cylinder actuator. Repeat over and over until you see no more bubbles in the fluid in the master cylinder.
Don't be surprised if this takes an hour or more, its very hard to bleed without a bleeder valve.
Turbo67
Jul 25, 2015 02:26 PM
daves3940
Mar 22, 2015 06:37 PM
bryan0702
Mar 18, 2015 05:03 PM
Kennyw250
Jan 14, 2015 07:47 PM
RamCamel
Dec 14, 2014 08:12 PM
