Vacuum Pump?????
Old Dec 27, 2011 | 10:08 AM
firemedic355's Avatar
Default Vacuum Pump?????
2nd gen. cant switch the from the defrost to any other position. blower motor is less than a year old and blows fine. heat and air work very good. Could this be the vacuum pump or something else?
I have a oil leak coming from that area also, could this be the problem??
Old Dec 27, 2011 | 10:17 AM
RAW's Avatar
RAW
Defrost is the default setting if the vacuum is removed from the HVAC system. I would be more suspicious of a vacuum line disconnected then a failed pump at this time. Does you 4x4 or cruise work? They are both vacuum controlled/assisted.
Old Dec 27, 2011 | 10:29 AM
i need to check the 4x4, but the cruise dont work either......?
Old Dec 27, 2011 | 10:31 AM
RAW's Avatar
RAW
I suggest looking for a detached line near the vacuum pump it's self. It probably just became disconnected.
As for the oil leak:
https://www.dieselbombers.com/24-val...mp-reseal.html
Old Dec 27, 2011 | 10:39 AM
cool i just replaced the driver wheel bearing and had to put it in the 4x4 to get it off and maybe i blew one off then. i hope it aint the pump.
thanks for the info!
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
InheritedDiesel
Apr 17, 2015 07:20 PM
DeLuzGN
Mar 17, 2015 08:08 AM
