help 400-500 hp ??????
Old Dec 26, 2011 | 08:35 PM
tmonroe's Avatar
ATTN help 400-500 hp ??????
what should i do to make 4-500 hp in my 97 cummins automatic trans.
Old Dec 26, 2011 | 08:58 PM
Red_Rattler's Avatar
High Tech Redneck
A goerend transmission and tripple disk converter for starters...
Old Dec 26, 2011 | 09:06 PM
tmonroe's Avatar
ok what about in the engine?
Old Dec 26, 2011 | 09:23 PM
High Tech Redneck
All the free mods to the pump, set of 5x14's, 4gsk, nice 62/65/12 turbo, 18* timing, head studs, exh, intake, gauges.... should get you in the ball park
Old Dec 26, 2011 | 09:30 PM
tmonroe's Avatar
free mods?
Old Dec 26, 2011 | 09:58 PM
moondiesel99's Avatar
free mods like grind the fuel plate down to a 0 and crank the star wheel all the way so youll get more fuel... correct? or at least thats what ive always hurd is free mods cause i know its supposed to add about 95 hp for free
Old Dec 27, 2011 | 12:19 AM
tmonroe's Avatar
Ya I've herd that to
Old Dec 27, 2011 | 05:25 PM
turbo2332's Avatar
research!!!!!
Old Dec 30, 2011 | 08:23 PM
Craig Ducharme's Avatar
So research is the big starting place for me. I made the mistake before becoming a member here of not taking my time and reading enough blogs and Internet posts on what to do and it cost me money I didn't need to spend, like the fuel plate. There is a lot good information like how to grind your fuel plate that would have saved me $265.00. There are people on this forum that run without them. For me I wanted a plate in my pump because I read you can damage the pump without one, which makes since to me as it stops the fuel slide from traveling to far and possibly causing damage. When you read enough you find out that you slide the plate all the way forward and the housing as well. This, with a bigger exhaust, I went to a 4" aFe, and a better intake, I went with an aFe Blade Runner, and you get a decent boost in the HP department. Now, the stock transmission is at risk in a big way and keeping your foot out of the peddle is really hard to do. I ordered the Georend full rebuild with billet flex plate, billet 3 disk converter, and a billet input shaft. I did a lot of research on this as this is pretty big dollars and Dave Georend seems to be the defacto expert in the field and is very competitive in price. Another place you find a lot of variation in price is in the injector department, I went to Pensacola Fuel Injection and for $200.00 I got a set of Stage 2 Injectors (70hp-90hp), no core charge. Now, I will probably buy 140 hp (5*.012 I think) Injector Tips and upgrade my stock Injectors but the Stage 2s I got were pop tested and my messing around will likely not be but I have a solid fall back plan. People here have done this and been successful which saves about $300.00. Another thing I have found is every piece costs ~$500.00 - $1000.00 so research is key if you don't have extra money to through around, even a set of head studs costs ~$400.00.
If your going to get into this expect to get your transmission built very soon if not first or go manual, which I have not researched.
Good luck!
Detroit Tahoe
Oct 5, 2015 05:17 PM
carid
Diesel Bombers Sponsors
Jul 16, 2015 05:11 AM
detroitdiesel idi
Dec 21, 2014 04:14 AM
