still having tranny issues
Old Dec 26, 2011 | 07:09 PM
jake 94's Avatar
Default still having tranny issues
Hey guys I fixed my tps but my trans still won't shift correct. At highway speeds it will shift normal till it gets warm then the trans temp light will come on and it will downshift into 3rd then the trans light will go off and it willl shift up and it will keep doing this untill I get off the highway. Sometimes the light will stay on for the hole ride home and won't come out of 3rd nomatter how hard I hammer the throttle
Old Dec 26, 2011 | 07:18 PM
turbo2332's Avatar
the OD cylonoid may be giving up??? do you have a lock-up switch? if so flip that baby when you are in third and see if it shifts and stays! that will let ya know
Old Dec 27, 2011 | 10:53 AM
jake 94's Avatar
Anybody else have any input I really need to figure this out need to get the truck back on the road any input helps thanks yall
Old Dec 27, 2011 | 11:14 AM
MillerBoyzDiesel's Avatar
could be temp sensor in trans. if they go out you will have 3rd gear only, even from a dead stop. check for codes. Ive seen gov. press. sensors and solenoids cause that problem minus the trans temp light.
Old Dec 27, 2011 | 12:18 PM
jake 94's Avatar
I checked codes and it said trans temp sensor reading to high. Would that make tbe trans do what its doing? Does that meen I need a new trans temp sensor
Old Dec 27, 2011 | 12:40 PM
youll need to check it but, yes it will put trans into limp and youll have only 3rd. you can check sensor ohms should be around 1000 ohms at room temperature. Check and see if the connector is secure too. The temp sensor should be part of the gov. press. sensor. If it tests bad id say youll wana tell the parts house you need a gov. press. sensor.
Old Dec 27, 2011 | 07:58 PM
mikej's Avatar
with the truck not started pull the shift lever into each gear if the indicator shows it is between gears adjust linkage.then at the drivers side top of the tranny unplug the overdrive connector then plug it back in this may reset overdrive.then strart it up let it idle about 25 minutes check for any fluid coming from the tranny inspection plate.a built tranny will shift fine until the fluid heats up overdrive will be the first to give trouble and you may have a seal or pump problem.when you have checked all the above get the solenoid pack scaned.chances are its not the temp sensor.
dwmeehan
Jan 29, 2025 12:13 PM
wilki
Feb 12, 2015 09:04 AM
Ol' RED!
Dec 11, 2014 10:00 AM
Polaris04
Dec 1, 2014 08:27 AM
Trevlar11
Nov 16, 2014 01:59 PM
