chugging help
Old Dec 26, 2011 | 07:26 PM
Bentley528's Avatar
Default chugging help
I am new to the site but not new top mechanics am fairly new to diesel and justpopped my Cummins cherry with this truck
My problem is I turned up my pump got it running good then I bought some used marine injectors and now the truck has a miss at 1000 to 1100 rpms then clears up and its mainly under load any help would be great cause I'm bout to get some delivery valves 3k gsk and timing bump will this help or make it worse
Do you think I should put my factory ones back in and get the marine injectors checked to see if one is weak or do you think they are just putting to much fuel in for factory timing
Last edited by Bentley528; Dec 26, 2011 at 07:26 PM. Reason: Automerged Doublepost
Old Dec 28, 2011 | 09:21 AM
Bentley528's Avatar
Dude people come here to get good advice and a&& holes like you f it up for every one I'm leaving in three months to go over seas and possible die for your dumb a&& besides was trying to make a joke
so if you don't have any constructive advice get lost
Old Dec 28, 2011 | 10:16 AM
mikej's Avatar
what size injectors
Old Dec 28, 2011 | 10:24 AM
Bentley528's Avatar
I believe they are the 370's but not positive
Old Dec 28, 2011 | 04:11 PM
mikej's Avatar
i have put in brand new injectors in my 96 and 06 both had a slight stumble when i would hammer it from a slow roll.i got a bigger charger on the 06 and it runs fine now.you may just need more air.i would first try changing the fuel filter and fill the filter housing full of injector cleaner
Old Dec 28, 2011 | 06:10 PM
Bentley528's Avatar
Its not when I hammer its when I am rolling along and it locks the converter at rpms around 1000 or if I power brake it at that rpm to act like I'm towing
Old Dec 30, 2011 | 06:53 AM
Bentley528's Avatar
Set up my appointment to get the work done so I will find it if more timing will fix my chug I think the new injectors aren't getting enough time for the fuel to burn properly and if it still chugs afterwords I still have my factory injectors
byronkgraham
Jun 26, 2015 05:01 AM
