anyone do a diy big line kit and draw straw?
Old Dec 25, 2011 | 08:39 PM
wilke12V's Avatar
Default anyone do a diy big line kit and draw straw?
Getting my new vp and ad150. And I'm wanting to put as much fuel to the vp as I can..and if i cab make it i won't buy it if its cheaper of course. But I need a plan first...i don't know what lines need to b replaced fir the big line kit..and I'm kinda clueless on the draw straw...any help would b great
Old Dec 26, 2011 | 09:49 AM
cummin_un_glued's Avatar
FormerVendor
use the draw straw V from vulcan that way you wont have problems when you get blow 1/4 tank of fuel, it goes inside your factory fuel cup in the sending unit. not just into the tank like the AD draw straw that comes with the kit.
the AD150 should come with all the lines and fittings to go all the way to the VP
Old Dec 26, 2011 | 01:53 PM
RAW's Avatar
RAW
The dsv is an awesome upgrade for the fuel basket. I've never had an issue with low fuel since I added one.
Old Dec 27, 2011 | 07:46 AM
EggosBrother's Avatar
^^^^What He Said!!! DSV is great and simple to install.
Old Dec 30, 2011 | 08:09 AM
wilke12V's Avatar
Thanks for the advise everyone...i just stayed up all night And got the new vp in and the ad150 everything went really smooth.
Old Dec 30, 2011 | 08:27 AM
RAW's Avatar
RAW
Good to hear!
Old Dec 30, 2011 | 11:28 AM
01quadcab's Avatar
I have had 0 issues running stock fuel tube with my truck. I guess I am lucky then. So I would say only change it if your getting rid of in tank fuel pump
Old Dec 31, 2011 | 09:31 PM
dukeboy_318's Avatar
I'm running a vulcan draw straw, 5/8 diameter to 1/2 inch fuel lines. I put mine in the tank just forward of the sending unit, I used 2 quarters, put them on the bottom of the tank and set the pipe to touch them and then cut the pipe to that length and removed the quarters, I've pulled 60% slopes and and in 3 years that its been in, I've never once had a 1/4 tank issue.
