banks big hoss / edge ez
Old Dec 25, 2011 | 04:37 PM
dieseldude848's Avatar
Default banks big hoss / edge ez
just finished installing the banks big hoss chip today, when i went to start it, it started knocking in the bottom end so i fethered the peddle till it warmed up, and it went away. do you think this is the new programer or the oil being thick? it was 25 degree's out, and havent ran it in a week. it never did it before with the edge ez. also banks seems like a better chip over the edge ez from what ive read, but after trying it out i see no gain. it now down shifts and it never did before when i was running the ez. the big hoss seems like its slower, so im not sure if i should go back to the edge or try this out for a while.
Old Dec 25, 2011 | 06:53 PM
Red_Rattler's Avatar
High Tech Redneck
No gain because you replaced it with the same kind of tuning. If you have the pryo wired into it it will also defuel at higher egts making it feel slower. There was def better options out there for 500 bucks... as for the knocking mines always louder at that temp plus it sat for a week, could have taken alil bit to get the oil flowing back where it should be.
Old Dec 25, 2011 | 07:28 PM
the truck came with the edge ez when i got it, and i picked up the big hoss off craigslist for $100. i never would have bought a new one for 400-500. and no i dont have the pyro hooked up to the box.
could i possibly stack the edge and banks?
Last edited by dieseldude848; Dec 25, 2011 at 07:28 PM. Reason: Automerged Doublepost
Old Dec 25, 2011 | 08:17 PM
High Tech Redneck
No because they both do the same thing
Old Dec 25, 2011 | 08:42 PM
how so? i thought when you stack them it whould combine both the power of the edge and banks
Old Dec 25, 2011 | 10:39 PM
High Tech Redneck
Because they both modify the map signal to make more power. That being said it can only be changed once therefore rendering one usless
Old Dec 25, 2011 | 10:48 PM
So say if I had somthing like a smarty that uses the obdII, then I would be able to get the power delivery out of both?
Old Dec 25, 2011 | 11:04 PM
High Tech Redneck
correct
Old Dec 26, 2011 | 06:16 PM
ok so today i put the edge back in just for *****, and it doesnt knock on cold start up anymore.
Old Dec 26, 2011 | 06:35 PM
High Tech Redneck
Its all in how they programed the tuner to gain the power. Every company has a different idea on how they want to make more power.
