Speedometer Correction
Old Jan 23, 2008 | 01:39 PM
fast450r's Avatar
Default Speedometer Correction
A budy of mine got pulled over for doing 73 when his speedometer said 62 and got a $75 fine so he needs to get it fixed,so whats the best way to fix it on a 97 12v
thanks
Old Jan 23, 2008 | 01:56 PM
Benjamin's Avatar
Bombardier
he must have big tires..... there is a gear/sensor on the rear driver side of the tail shaft. mine was black. it'll have a bolt to the right of it if i recall correctly that applies pressure to a "fork" that pushes on the sensor to hold it in place. depending on what gears he has he might be able to get a different one and see if that makes it closer. if he has 3.54's then he could get one from a 4.11 truck and it'll be alot closer with those tires (assuming it is them causing it) if not i bet you can call Dave at Goerend Brothers Transmissions and he can tell you the proper way. he went over it with me and i can't remember what all he said exactly. www.goerend.com
hope this helps
Old Jan 23, 2008 | 03:14 PM
fast450r's Avatar
ok thanks,ya he has 35s
Old Jan 23, 2008 | 04:00 PM
DangerousDuramax's Avatar
TS Performance also sells a product called "Respeed" that corrects for tire size.
Old Jan 23, 2008 | 04:11 PM
Benjamin's Avatar
Bombardier
1190102 is the part number for it, the respeed, for his truck. the only downside to me is it is showing MSRP of $299
Old Jan 23, 2008 | 04:13 PM
Didnt know that.
Old Jan 25, 2008 | 03:50 PM
NMCUMMINS's Avatar
Have him measure the height of his tires and find out what gears he has (3.54, 4.10) and I'll run the numbers and give you a part number for the speedo gear to correct it, it may not be perfect, but we should be able to get him withing 2mph. The replacement gears are about $7 online or he can get it from a local dealer for under $20.
....Josh
DirtyDiesel58
18
Sep 27, 2015 07:07 AM
Powerstroke36
Sep 21, 2015 08:32 PM
Big Mike 62
Aug 27, 2015 08:29 PM
wood2turn
Chevy/GMC Duramax 04.5-05 LLY
Jan 1, 2015 07:28 PM
cumminsgen2
Oct 16, 2014 09:46 AM
