lift kit
Old Dec 25, 2011 | 10:01 AM
southernman1967's Avatar
Default lift kit
how do i tell how tall my lift kit is? also how reliable are these trucks and what are the weak points, will be my daily driver, has 156,xxx on it now. how do post pics on forum?
guess im the first with a lift here!
Last edited by southernman1967; Dec 25, 2011 at 10:01 AM. Reason: Automerged Doublepost
Old Dec 25, 2011 | 10:13 AM
Red_Rattler's Avatar
High Tech Redneck
Hard to tell without actually seeing the truck... Any pics of the suspension setup? These trucks are very reliable. Only issuses I had with mine is a water pump, one set or pads, 1 set of wheel bearings and a new drag link with outer tie rod ends. As for posting pics, when you typing a reply go to advanced mode and click attachments and load them directly from your pc or make an account on photobucket and copy the image links from there.
Old Dec 25, 2011 | 10:41 AM
thanks will get pics up
Old Dec 27, 2011 | 09:05 AM
1AMatt's Avatar
Site Sponsor - 1aauto
Are there coil spacers in the front of the truck, or is it all spring?
Old Dec 27, 2011 | 07:33 PM
It's all springs
Old Dec 28, 2011 | 08:24 AM
sillyneck's Avatar
to clear 35's all you "need" is a leveling kit. So since it's a spring lift it's probably 3" or taller.
if the rear lift is just blocks (which is pretty common) you can measure the block. If it doesn't have the "dirty white boy rake" and it's pretty level.. if you find you have a 2" block you probably have a 4" lift. 4" block = 6" lift. 2-3" leveling springs generally don't get a block at all.
If it has stock control arms it's not likely more than a 3" lift.
An aftermarket lower with stock upper, not likely more than 4"
More than 4" lift with short arms = horrible ride. Upgrade to a long arm kit. (preferably mine (sfsindustries))
Apr 29, 2015 08:20 AM
slowstroke
For Sale
Mar 27, 2015 05:19 PM
Ruddedawg5.9
Feb 22, 2015 10:54 PM
turbodiesel123
Oct 24, 2014 10:27 PM
JJ Diesel
Oct 6, 2014 11:21 PM
