6.0 loses power
Old Dec 24, 2011 | 02:56 AM
farmboydiesel's Avatar
Default 6.0 loses power
I have a 03 6.0 with 139k on it. A old man owned it it was bone stock. I straight piped it and put the bullydog triple programmer on it since it'll be in Hawaii. FYI-I am gettin ride of the bullydog and gettin a sct. i ran it a week with the programmer. after gettin off the interstate i stopped at a stop sign when i took off it barely went anywhere even when i put it to the floor. It happend 2 more times that night. Any help/advice would be greatly appreciated
Old Dec 24, 2011 | 04:11 AM
brondondolon's Avatar
Any check engine lights?
Also u say it did it two more times that night. So when it did it it only did it at the one light and then drove fine after you got up to speed? Or was it sluggish though out the whole drive? Any smoke or other abnormalities?
Last edited by brondondolon; Dec 24, 2011 at 04:11 AM. Reason: Automerged Doublepost
Old Dec 24, 2011 | 11:03 AM
Cummins100's Avatar
Did you have any problems before this?
Old Dec 24, 2011 | 11:14 AM
03Powerstroke's Avatar
and if it is smoking what color, smell, and how much?
Old Dec 24, 2011 | 12:32 PM
Mdub707's Avatar
Definitely need more info. Read the sticky at the top of the page.
Old Dec 24, 2011 | 10:42 PM
Didn't see any smoke that I could see it would jus hesitate for a couple seconds right at a high idle like then itd pick up and do just fine. Each time it did it that night I was stopped. Almost like the fuel pump wasnt pickin up at first
Ran perfect though before still runs normal though other then that experience
Last edited by farmboydiesel; Dec 24, 2011 at 10:42 PM. Reason: Automerged Doublepost
Old Dec 25, 2011 | 12:12 AM
Arsenal's Avatar
How does it start? Hot/cold effect it at all? If you have access to a scan tool, i would run an injector buzz test and a cylinder contribution test. Have you checked the EGR valve yet? I hesitate to throw out any "could be this" statements cause thats no better than half the hack a$$ stealership service writers out there.
Old Dec 25, 2011 | 03:24 AM
Starts runs drives fine
Old Dec 25, 2011 | 02:30 PM
Karls03's Avatar
Have you removed the Triple Dog to rule it out? I would discon both batteries for about an hour to ensure the compters reset. I've pulled stuff iff if mine and had to do this.
Old Dec 25, 2011 | 02:38 PM
I was maybe thinkin that my fuel pump could possibly be startin to fail might not be able to bring all the fuel to it that its wantin
