P7100 bushings
Old Dec 22, 2011 | 08:43 PM
KingCopa's Avatar
Default P7100 bushings
A couple months ago my uncle was having problems with his throttle rods binding up and not letting the truck go faster then 25mph unless he stood on it. Well he pulled it apart to rebuild it it turns out there are some bushings that hold the rods and they got wallowed out making the rod bind. Has anyone else had or heard of this issue and where he might be able to get just the bushings? The dealer doesn't sell just the bushings just the whole pump.
Old Dec 29, 2011 | 01:44 AM
12v15004x4's Avatar
This should help
Throttle Linkage Play - P7100 - Dodge Cummins Diesel Forum
Old Dec 29, 2011 | 06:14 PM
Pyro690's Avatar
The bushings on the front of the pump where the cable connects?
Old Dec 29, 2011 | 08:34 PM
12v15004x4's Avatar
If you notice bushing number 4 is for the pivot for the linkage that connects the throttle cable.
Old Dec 29, 2011 | 09:13 PM
mysterync's Avatar
Cummins keeps these parts in stock, pure diesel power also Carries them. Most likely its going to need a bell crank as well. The lever or bell crank is part number 3931569 at Cummins. 3914353 are the bushings and you need two.
Sent from my DROID BIONIC using Tapatalk
CGwill
Apr 21, 2016 10:13 PM
cfarley0210
Jan 19, 2015 06:00 PM
mark402001
Tire, Wheel & Suspension
Jan 18, 2015 03:17 PM
Mr. Walkway
Dec 11, 2014 10:28 AM
rambo58
12
Dec 7, 2014 06:49 AM
