FICM Test
Old Dec 22, 2011 | 12:57 PM
bkmac's Avatar
Default FICM Test
06 6.0 PSD Automatic
Opened up the box and my 4 screws are up and down not right to left. Is it the bottom screw to use for the test?
Old Dec 22, 2011 | 01:02 PM
Mdub707's Avatar
Up and down? They should run side to side of the truck, not front to back. If you have 4 pins, test the one closest to the drivers side. Red probe on that screw, black probe on the negative terminal on the battery.
Old Dec 22, 2011 | 01:07 PM
bkmac's Avatar
Yea they dont run fron to back but are up and down
Like that so not sure which one to use -
Old Dec 22, 2011 | 01:28 PM
Mdub707's Avatar
Take a picture please. I'm not sure what you mean by up and down. The FICM is mounted on the valve cover, so it sits at a bit of an angle. The pins run from side to side of the truck, in line. The one you need is the one closest to the drivers side.
Old Dec 22, 2011 | 01:30 PM
bkmac's Avatar
The rusty washers are to the FRONT of the driver's side valve cover - the screws are staged up and down
Old Dec 22, 2011 | 01:45 PM
bkmac's Avatar
Another shot
Old Dec 22, 2011 | 02:00 PM
03Powerstroke's Avatar
the bottom one is the same as drivers side one, same thing... thats how they all look
Old Dec 22, 2011 | 02:51 PM
bkmac's Avatar
Mdub & Powerstroke thank you both for your rapid response. The FICM tested fine
Old Dec 22, 2011 | 05:14 PM
is the truck running bad?? why were you testing it?
Old Dec 22, 2011 | 06:03 PM
bkmac's Avatar
Starts hard and runs rough until it warms up.
If plugged in starts ok but still runs rough until it warms up.
