Trouble with starting after modding
Old Dec 21, 2011 | 09:44 PM
twinstang's Avatar
Default Trouble with starting after modding
I have a 95 12 vavle with some slight mods. It has 4 inch exhaust and had a number 4 fuel plate that I just ground down to look like a #100. I moved it all the way forward along with the afc. I also turned the gov springs in 3 clicks and turned the star wheel to the point where you almost can't turn it anymore because its so far in. The truck feels like a totally different truck. I have owened this truck for almost 15 years and I wish I had did this sooner.
My question is I know have to give it gas to get it started and when it's totally cold it's real hard to get started and when you give it gas it stalls until it starts to warm up. I know it's fuel related but I was under the impression that the smoke screw was what controlled the pre boost fuel so I'm not sure what needs to be done. I have not touched the smoke screw just yet. Should I turn the star wheel back or move the afc back ?
New to bombing diesels so please bare with me.
Old Dec 21, 2011 | 10:12 PM
Red_Rattler's Avatar
High Tech Redneck
Whats it idle at when you get it started?
Old Dec 21, 2011 | 10:15 PM
twinstang's Avatar
It was to high so I turned it down around 900 to 1000 rpm
Old Dec 21, 2011 | 11:11 PM
MillerBoyzDiesel's Avatar
I would take the 3 clicks back out of the gov. springs.
Old Dec 21, 2011 | 11:23 PM
dezzrats's Avatar
X2 on the Gov. springs
Old Dec 22, 2011 | 01:15 AM
captain_stabbin's Avatar
when you turned them 3 clicks, did you do both sides?
Old Dec 22, 2011 | 08:38 AM
sounds like when you clicked in your gov. springs 3 times you put to much preload on your idle springs. If you wana play with the stock gov. springs you should add shims behind the rpm springs. If you put too much tension on the idle springs youll get the starting/idling problem you have.
Old Dec 22, 2011 | 03:19 PM
twinstang's Avatar
Ok thanks I did do both sides, if I do the 3k or 4k springs the proper way then this should solve my problem ? I just love how much different the truck responds after the 3 clicks its like a whole different truck.
dskewes14
Sep 14, 2015 09:19 AM
GasItOut
35
Jul 22, 2015 01:11 PM
gunman41mag
The Sportsmen's Lounge
Jul 1, 2015 10:21 AM
hurriedcoyte
Jun 19, 2015 06:26 AM
7.3stroke
Oct 27, 2014 06:25 PM
