transmission rebuild
Old Dec 21, 2011 | 01:04 PM
lt smoke's Avatar
Default transmission rebuild
any one have their nv 4500 rebuilt ...and if so has any one used any oil other than the castrol syntorque ....and what if any issues ? reason i ask is i just rebuilt mine and am going to put lucas 85-90 transmission lube rated for gl-4 in due to not being able to find the castrol
Old Dec 22, 2011 | 05:51 PM
cummins270's Avatar
I just rebuilt mine and they say not to put that in there. I put syncro mesh back in mine
Old Dec 22, 2011 | 11:48 PM
01quadcab's Avatar
I ran the amsoil in my 99 when it was done with no issues I am not sure about the lucas haven't always had great luck with them but have not ran that in the 5spd the amsoil is a 75-90. you can contact heath on getting it shipped to your door
You put 6spd fluid in the 5spd?
Old Dec 23, 2011 | 12:34 AM
mysterync's Avatar
Don't run anything but the syncro mesh. You can use Pennzoil or another brand but if you like your transmission get the Lucas out of it.
Old Dec 24, 2011 | 10:24 AM
BarryB's Avatar
If you use any other oil in your trans, you can hurt the syncro's. The regular oil has component that will eat at your carbon pads on the brass syncro's. The syntorque doesn't have these components. Amsoil has a real oil you can use. Amsoil is what I used in mine when I rebuilt mine. The guy that bought the truck from me started running lucas in it, he didn't run it to long before it started being hard to shift and not going into gear properly. so I'd say play it safe and just use what is recommended.
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
Trevlar11
Dec 11, 2014 03:30 PM
W350-4x4
Nov 12, 2014 09:35 AM
TheDirtyDozen
Oct 1, 2014 10:09 AM
