1993 Dodge W250
Old Dec 21, 2011 | 11:20 AM
W250's Avatar
Default 1993 Dodge W250
Hey guys, I've recently baught a 1993 dodge w250, now I know diesels are slow going and not peppy bit mine seems like it doesn't have much give? I get 115 kmh out of it, also I've been told they have turbo problems, can anyone help me
Also my truck is lower in the front then the back, what can I do to level it? Thanks guys!
Old Dec 21, 2011 | 01:19 PM
ricet07's Avatar
Do you know if it has a the stock turbo on it? If someone put a turbo with a bigger turbo on it, it might be laggy. Also look in the sticky for pump mods and start tweakin if you want more out of her. <--(Make sure to get a set of gauges first) Check your turbo for shaft play, it might need a rebuild. Check out Denny T and get yourself a fuel pin also a 3.2k gov spring, wouldnt hurt to throw alittle timing at it too (1/8") is all the further you will want to go for a slight fuel mods that you will do. As far as the leveling IMO you would be better off getting a set of 2" springs all around and it will ride a little better and give it a better stance. Good Luck!
David90
Sep 16, 2015 12:48 PM
dlpannebakker
Jun 26, 2015 04:23 PM
splott
May 11, 2015 09:21 AM
Mar 23, 2015 08:10 AM
Tucker126
Jan 2, 2015 08:09 AM
