CEL P2290 ?
Old Dec 21, 2011 | 05:09 AM
brondondolon's Avatar
Default CEL P2290 ?
Driving my truck on my lunch at work and stomped on it to see if there was a difference after using diesel kleen and replacing one of the two fuel filters when all of a sudden my check engine light came on so being as I bring my scanner in almost every car i drive in I scanned the ecu and pulled one code for the injector control valve i believe it said. The code was p2290 any one know what this means? HPOP?
Thanks guys
Old Dec 21, 2011 | 08:36 AM
Mdub707's Avatar
2290 is ICP too low. (ICP = injection control pressure). Could be a number of things. Could be the sensor itself going out, which is common on the 03 and early 04 trucks. The sensor is behind the turbo, look to see if it's soaked in oil. If it is, replace the sensor and the harness. Could also be a high pressure oil leak, or the HPOP on it's way out.
Personally, I'd probably clear the code and drive the truck to see if it returns.
Old Dec 21, 2011 | 02:56 PM
I cleared all codes the day I got it and thats the only code that returned do you think this code is causing my truck to feel slow ?
Old Dec 21, 2011 | 03:20 PM
Mdub707's Avatar
Very well could be yes. However it's relative... I think these trucks are ridiculously slow stock as it is...
Old Dec 21, 2011 | 06:42 PM
I can't wait till all the maintenance stuff is all out of the way so I can get the studs done and chip it.
I pulled the other fuel filter today i took a pic ill post it in the "better mpg?" Thread in about an hour it was pretty bad
schmauster
Jul 26, 2015 11:33 AM
74shovel
May 29, 2015 04:25 AM
J_stout
Dec 14, 2014 07:23 PM
bajahigh
Dec 9, 2014 09:23 PM
Stick_Welder
9
Oct 24, 2014 04:10 AM
