Fuel usage very weird
Old Dec 19, 2011 | 12:18 AM
beast6.5's Avatar
Default Fuel usage very weird
Ok my friend has a 1996 5 speed with a 5 inch and a #10 plate, soot spittin threw all gears all the way to red line(fades as you go) can beat the crap out of it and barly use fuel. My 160 pump before i 100'd the plate it wouldnt do that. i have drivin about 805 miles in the last 18 days and put about 50-60 gallons in so thats like 16-13 mpg and yes i play with it but not all the time everyday. that was with a 180 pump stock fuel plate push all the way forward. the only thing i know that is wrong with the truck is the waste gate is locked up and the tube that is suppose to go to the waste gate hard line by the pump is pluged. WHY IS THAT???
P.S What can i look for other then the waste gate to have this happening? fuel pressure to the pump? bad injectors??
Drive test for PSI at 30mph ish its at like 2 psi and 52 mpg in 4th is like 6 psi.
I will be taking the pump off tomorrow after work and give more feed back after.
Old Dec 19, 2011 | 03:56 PM
tiremann9669's Avatar
Look for your buddy siphoning your tank in the middle of the night
Old Dec 19, 2011 | 11:30 PM
beast6.5's Avatar
No we narrowed down the things it could be and we came up with the pump timing slipped.
Dbleo351
Nov 20, 2016 09:34 AM
Powerstroke36
Sep 21, 2015 08:32 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
