afc tuning(new england tread with p pump cut out)
Old Dec 16, 2011 | 11:45 PM
beast6.5's Avatar
Default afc tuning(new england tread with p pump cut out)
Ya long title, i figured it i just wrote afc tuning no one would write because its on here 500 times.
12 Valve AFC Mod's - New England Turbo Diesel Power
With that said I have read the entire post 3 times ^ and under stand pretty much everything very well. the only question i have is at this moment my waste gate is locked up rusted. "hucksdorf diesel of racine wisconsin" said it shouldnt be a problem tell you get to the 40 psi range. Now if is that because the diaphragm wouldnt be adjusted by the boost pressure and cause to much air and not enough fuel?? With the waste gate the way it is if i make a 100 plate from and extra stocker plate where would i need the afc housing so i dont hit 40 psi??
thanks for the help if there is someone that can answer that for me.
Old Dec 17, 2011 | 12:04 AM
Red_Rattler's Avatar
High Tech Redneck
Your ok to 35, 40's pushing it but after that the drive pressure is way outa wack and not good for cyclinder pressures and the turbo itself. With a 100 plate and stock everything else you wont hit 40psi so you'll be fine.
Old Dec 18, 2011 | 11:26 AM
beast6.5's Avatar
ok well i ground the plate and put it in. I have the star wheel about 1/4 inch from the front of the hole. all i get is a little pluff of smoke and thats it. is this normal??? should there be more, or less?? it seems to have a little better pick up and better top end. would the fact my waste gate is locked up and the vacuum line from it plugged do anything?
Old Dec 18, 2011 | 12:28 PM
High Tech Redneck
so the boost line that goes to the afc is plugged? Thats a problem if it is
Old Dec 18, 2011 | 01:36 PM
beast6.5's Avatar
I think its the vac line that goes to the wastegate. Because when i take the plug out and hook it up i only get 8 PSI ish.
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
