99 dodgeram diesel battey drain at fuse 12 i.o.d
Old Dec 16, 2011 | 10:19 PM
jsdidrick's Avatar
Default 99 dodgeram diesel battey drain at fuse 12 i.o.d
Sounds like the number 12 i.o.d. 10 amp fuse is for the interior of the truck. unplugged door switches, glove compartment, took out interior lamp bulbs, still draining.I am fairly sure i am at the correct circut as when I unplug the fuse the multi meter is under 0.025.
Anything Ideas? Thanks
Old Dec 16, 2011 | 10:28 PM
MillerBoyzDiesel's Avatar
youll have no comm. with ecm using a scan tool if that fuse is out, think the ecm uses that fuse too. how long did you let truck sit before you started pulling fuses? not for sure about dodge but sometimes it can take 15 to 20 mins for everything to shutdown on some vehicles
Old Dec 16, 2011 | 10:31 PM
mysterync's Avatar
Yep. Need to wait at least one hour. The circuit will still continue to draw even after that point.
Old Dec 16, 2011 | 10:36 PM
jsdidrick's Avatar
ok, I will try it again tomorrow and give it more time, thanks
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
david.burger
May 30, 2015 08:25 AM
wolfnexus
Nov 4, 2014 10:04 PM
