95 tranny
Old Dec 16, 2011 | 10:10 PM
somkingcummins95's Avatar
Question 95 tranny
is a 95 transmission a 47rh or 47re?
Old Dec 16, 2011 | 10:54 PM
MillerBoyzDiesel's Avatar
think last year for rh is 96 so id say its rh. only diff. is manual gov. vs re electronic gov.
Old Dec 19, 2011 | 11:39 AM
ok cause i need to get a shift kit for my 95 cause i pumped it up a little bit
Old Dec 20, 2011 | 07:28 AM
cumminspwr11's Avatar
the shift kits are the same for the re and rh, they included parts for the re that you dont use in the rh, its just a little resister to fool the electronic re governor, other than that they are the same transmission, OD housing is different but all the parts except for the output shaft and the housing are the same
Old Dec 20, 2011 | 10:18 PM
young gun's Avatar
47rh and a shift kit will just firm up the shifts. .the trans runs off fluid pressure and the lower the engine rpms the lower the trans fluid pressure. if you really want to save your trans get few small pump mods done to the trans. it;ll save more in the long run
Old Dec 21, 2011 | 06:39 PM
im one step above stock and they said i need a shift kit its pumping 255 its 100 extra hp whats the best kit to get?
InheritedDiesel
Jun 3, 2015 09:39 PM
peterbilt
Chevy/GMC Duramax 06-07 LBZ
Apr 8, 2015 10:33 AM
wilki
Feb 12, 2015 09:04 AM
Ol' RED!
Dec 11, 2014 10:00 AM
Trevlar11
Nov 16, 2014 01:59 PM
