support bearing replaced and still having problems
Old Dec 16, 2011 | 05:13 PM
vinnie0104's Avatar
Default support bearing replaced and still having problems
I had a loud popping noise while driving at around 50 or so mph from what sounded like the drive shaft. checked the u-joints and they were good. Ended up replacing the center support bearing as it was going bad. Figured it would fix the problem. Just test drove the truck and can still hear a ruff noise while the truck is going around 15-20, as well at the popping sound while driving 50.
Anyone have any idea what else could be wrong? i appreciate any help. thanks
Old Dec 17, 2011 | 12:16 AM
Bigg Redd's Avatar
Is the Popping noise constant, intermitent, or occasional? "Rough noise" kinda open to interpretation. Any vibration issues? Clarify if possible. Sound travels very well through metal.
Old Dec 17, 2011 | 10:06 AM
vinnie0104's Avatar
the popping is consistant everytime i get up to 50-60, but i havent continued to drive that speed to find out. no real apparent vibration issues. the truck is lifted and on some knobby tires so no more vibration than normal. and the rough noise is hard to describe almost like bearings rubbing on each other or metal on meatl grinding
Old Dec 17, 2011 | 04:07 PM
Bigg Redd's Avatar
Sorry vinnie, I have more questions I just thought of as I read your reply. Im still trying to figure it out.
1. Is your truck 4x4? tire size? stock gears?
2. Possibly a front wheel bearing? Check for play.
3. trans temps within limits? maybe a failing trans. check fluid for burnt smell, check trans pan for metal particles/ chunks. Torque converter issues.....
4. Rear gears or bearings possibly wearing/worn. last diff lube change?
5. How many miles on your truck?
Tough one for sure.
I didnt see a signature on your thread. Might help to see what kind of goodies youve bombed your truck with.
Old Dec 17, 2011 | 04:50 PM
vinnie0104's Avatar
its 4x4 with 8inch lift with 38/15.50/18. truck is stock just got it not to long ago. its got 99500 on it. trans temp not to sure about but it does it with or with out being fully heated up. and as far as the diff lube change not sure. Was actually about to change with the oil this weekend
Old Dec 17, 2011 | 11:36 PM
Bigg Redd's Avatar
A possible failing trans and/or torque converter comes to mind. Might even be a failing or failed flex plate. I didnt ask, but Im assuming you have an auto trans?
If manual trans, I would lean towards possible clutch, throwout bearing issues.
Im hoping someone who has experienced this sort of thing chimes in.
This, of course, is just off the top of my head though. Hope this helps.
Old Dec 18, 2011 | 06:39 PM
cerberus60's Avatar
Front wheel bearings, check them quick or the wheel falls off.
Old Dec 18, 2011 | 06:55 PM
Bigg Redd's Avatar
That would be a memorable experience. Hope its an easy fix though. Sorry if I wasnt much help!
Old Dec 19, 2011 | 10:43 PM
Bigg Redd's Avatar
Hey vinnie, is there any way you can post a sound clip of the noise youre experiencing? If possible that is..........
Im still stumped.
Old Dec 20, 2011 | 05:37 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Where is the noise coming from? Is it a long arm lift?
