12valve tuning? I need help!
Old Dec 14, 2011 | 01:09 PM
M-Schuler's Avatar
Default 12valve tuning? I need help!
I need advice on how to tune up my 12valve. I cut my fuel plate and turned the star gear.. what else can i do to get more power out of it?
Old Dec 14, 2011 | 01:14 PM
MillerBoyzDiesel's Avatar
timing advance, fueling adjustments at back of pump, set valve lash. whole bunch you could do if you wana spend some money
Old Dec 14, 2011 | 01:18 PM
M-Schuler's Avatar
yeah thats just it.. no money.. no job.. so im lookin to do what i can with whats there with the stock parts
Old Dec 14, 2011 | 01:22 PM
well timing and pumps tweaks are free, youll need to borrow a timing gauge or timing tape from somewhere though
Old Dec 14, 2011 | 01:25 PM
M-Schuler's Avatar
alright.. how much would you say i should advance the timing?
Old Dec 14, 2011 | 01:29 PM
well theres alot of diff. answers there some ppl will say 1 degree on stock truck then others will crank em on up farther than that, heavy mods ive set em as high as 24 degrees on a street driven truck. if its pretty much stock i like 17 to 18 degrees base timing. you can play around with it and see where it runs best, gauges are a big help in determining a good number.
Old Dec 14, 2011 | 01:34 PM
M-Schuler's Avatar
alright thanks
Old Dec 15, 2011 | 02:19 PM
turbo2332's Avatar
free or almost free mods.
- grind a plate
- tune your afc
-shim your gov springs or (spend the cash on some 4ks if youve got it. ABSOLUTE night and day different truck. PROMISE!
-get a boost elbow so you can run low 30's lbs of boost
-while your in the afc do the washer flip mod or get fender washers and grind the foot.
-a mack plug is like $12 that adds sever ponies at WOT
-good intake and exhaust (money of coarse
-and at this point your tranny is going to start hating you.
https://www.dieselbombers.com/12-val...gine-mods.html
Old Dec 16, 2011 | 11:34 AM
M-Schuler's Avatar
the fuel plate is a #0.. i turned the star gear all the way up and did the afc screw out just abit to where it feels good.. also i plugged the wastegate on the turbo.. and i got a manual with a upgraded clutch so i dont have to worry to much.. ive looked into 4k springs and havent heard about the mack plug.
Old Dec 16, 2011 | 11:42 AM
mack rack plug is made deeper, allows more rack travel
