2005 F250 power steering oil cooler info!
Old Dec 14, 2011 | 12:18 PM
justanother92's Avatar
Default 2005 F250 power steering oil cooler info!
Hey guys just thought i would post my findings on a leaking power steering cooler. So heres the deal turns out the factory fog lamp wiring harness was rubbing on the upper cooler inlet nipple and created a hole! So in saying that i just thougt i would let others know about it so you could possibly save yourself a break down. The cooler through Ford is around 60 bucks! I had mine tig welded and seems to be working fine.
Old May 2, 2020 | 11:18 AM
kgoforth1's Avatar
Hi there. I'm curious if this fix held up just fine for you. I have the same problem.
Old May 2, 2020 | 08:43 PM
bismic1's Avatar
In case the OP (who was last seen here 7 years ago) doesn't respond, the OEM cooler part # is 6C3Z-3D746-AC
bypass-21
Dec 15, 2014 08:52 AM
Jgoff35
Feb 27, 2014 03:00 PM
gonzarelli
8
Nov 15, 2011 12:29 PM
Chief Engineer
Jul 21, 2011 05:47 PM
GWL
May 10, 2011 11:15 AM
