BD-Power Visit - BD-Power
New from BD Diesel Perf, Duramax FleX-plate
Old Dec 14, 2011 | 11:01 AM
Blair@BD's Avatar
FormerVendor
Default New from BD Diesel Perf, Duramax FleX-plate
BD’s Duramax Black FleXplate is designed to reliably handle up to 1,500 lb-ft of torque. Featuring twice the material of the Stock flex plate, these units are billet machined, precision balanced. SFI 29.3 approved for use in racing sanctioning bodies. Black Oxide coated to resist corrosion and prevents hydrogen embrittlement that can cause cracking, these units will fit any OEM or aftermarket torque convertor and affordable enough to replace with a convertor or transmission swap.
Why replace the entire flywheel assembly when it’s the flex plate that is the problem? Save your powertrain! BD’s FleXplate still allows axial thrust unlike the competitors solid flywheel conversions. The BD Black FleXplate is a direct bolt-in replacement for the stock unit – one part number covers all Duramax years. Great for racing, Towing or stock application.
BD FleXplate has passed the newly created SFI 29.3 version testing – a much more stringent test for safety then the old 29.1 version. The 29.3 test is specific to the high horsepower Diesel engines only. The BD FleXplate is high speed Neutral Balanced almost twice as thick as the stock unit, the material is 30% stronger. This again points to the BD FleXplate as being the best in the industry.
Feel free to contact me for any technical questions or for Product pricing and availablity contact any of our Dieselbombers BD Diesel Supporting dealers.
Regards,
Hector
Attached Thumbnails New from BD Diesel Perf, Duramax FleX-plate-bd-duramax-flexplatelowresflexplate.jpg
shane509
Potential Diesel Owners Forum
Sep 15, 2015 08:41 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
cdetterer
Jan 22, 2015 08:38 PM
hardeercy
Nov 6, 2014 08:08 PM
wolfnexus
Nov 4, 2014 10:04 PM
