where do i get rear brake lines
Old Dec 13, 2011 | 09:05 PM
1993firstgennewbie's Avatar
Default where do i get rear brake lines
does anybody know where to get pre made brake lines I just replaced every part on my rear brakes and my brake lines are also bad
Old Dec 13, 2011 | 09:28 PM
Gas's Avatar
Gas
RockAuto.com
Old Dec 14, 2011 | 02:33 PM
God this is starting to **** me of Im having a guy here in denver do my lines called custom fits and he came out to my house to pick up my old lines but when I finaly got the line out of the valve on the axle its stripped and no good I went and picked up a new one from napa and this is gona be a pain in the *** to remove does anybody have any pointers? do I have to drop the tank? this is by far the worst brake job of my life most expensive too Im at 400 bucks and my truck is still not moving
Old Dec 14, 2011 | 05:08 PM
tower_ofpower's Avatar
400 is cheap... Try owning a Bonneville and having to sink $800 bucks into the brakes... Did one when I was working at a small garage. I would have junked the car for that much . Soak everything in PB Blaster and get some vice grips. It'll come out.
Old Dec 20, 2011 | 01:14 PM
Im finaly done with this all of my brake parts are new except my power booster since i did my master cylnder front calipers rotars and pads last year. in all my rear brakes cost me about $480 so my advice to anyone with rear drum brakes is dont just let your rear brakes go to **** and not fix them like the guy that owned my truck before me did. I even found some parts left over from the previous brake jobs
Old Dec 20, 2011 | 03:42 PM
That93Guy's Avatar
Was worried about throwing "vise grips" out there for fear of being Chastised, but that's pretty much what it comes down to most of the time... I definitely know this situation well, I swear ive had to vice grip out the stupid things on 4 or 5 different trucks, and replace the lines... I usually just buy the straight lines at Napa and bend them to fit myself.
Old Dec 20, 2011 | 05:47 PM
Vice grips become the "proper tool" when no other tool works, aka stripped although if you were to use the proper tool from the get go, (flare nut wrench) it's less likely you'll strip it out and have to break out the redneck tool box
Old Dec 24, 2011 | 08:46 PM
u2slow's Avatar
All I ever use is the pre-made lengths with flare nuts already on. Just make enough gentle bends to get the job done. Replicating the 'digital waveform' of the stock line isn't necessary. Any extra length you can take up with an extra 'U' or 'S' shape.
weatherby
Aug 31, 2015 08:04 PM
Turbo67
Jul 25, 2015 02:26 PM
corksil
Jun 30, 2015 06:58 AM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
yams
Nov 29, 2014 09:25 PM
