AirDog150 Users...What Kind Of FP Are You Seeing?
What kind of FP are yall seeing with the AirDog150??? Also are yall seeing a constant/steady FP?
I can't get a steady FP at all. It varies from 12.5 to 19. It just depends on what the pump wants to do that day. Also the FP is not steady. It will build up slowly to 19spi and drop back down to 15 or 12-12.5, but it usually drops to 15.
I posted this on another forum, so some of you may have seen this already.
I used teflon tape on all the fittings and I don't have any leaks on the connections. I'll be calling charlie tomorrow actually.
It's crazy because the first 2 days of having it on the truck I saw a constant 21psi and would only drop about 3 psi during a short WOT run.
not sure which air dog I have but the pressure is between 24 and 20psi no logical reason when it is higher or lower that I can reason. I have both digital and mechanicl gauge. digital reads 20 to 17 psi never lower.
