Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
lly fpr small lope?
Old Dec 11, 2011 | 11:11 AM
2004llygmc's Avatar
Default lly fpr small lope?
my truck has a small lope nothing major you really cant tell it in the rpms but it is a small sorta fast lope maybe at a 1 sec interval between each one. but it only does it in drive while its under a load i guess is the only time it triggers it, never in park though. there have been very few times you could see the rpms jump and they were very little mabe 50-75rpms i was thinking possibly the fpr is going out that seems to be a common problem with these llys
this truck is bone stock 60,000 miles any help?
Old Dec 12, 2011 | 07:32 AM
cummin_un_glued's Avatar
FormerVendor
we have changed a couple of the regs on the llys for similar problems, if you have a way to watch the rail press you can tell, should see the actual bouncing higher then the desired
Old Dec 12, 2011 | 08:20 AM
COTNP Tuner's Avatar
FormerVendor
There were some calibration updates on the LLY for this. Might want to check with the dealer or get someone with EFI Live to take a look.
Old Dec 12, 2011 | 04:42 PM
2004llygmc's Avatar
thanks guys i was just hoping this was no major issue im new to the diesel world ive had gassers all my life but it dosent seem to hurt the perfomance any to me i have a buddy with a edge where i can monitor my rail pressure when i get to that ill post the recorded pressures im not to sure what numbers i need to be looking for on there
Bigredpowerstroke
Aug 14, 2015 10:31 AM
May 8, 2015 08:30 AM
duramaxtuner
04.5-05 LLY Performance
Dec 10, 2014 01:56 PM
Nov 1, 2014 04:20 PM
