HELP lots of white smoke
I have an 04 f350. The other day It started to idle rough and produce a lot of white smoke. once past idle it runs fine and when i let off the pedal it has one large puff of white smoke. I checked it with AI no trouble code. Talked a tech he said it was the ERG so I got a delete kit and its still doing it. its not using water as far as i can tell. Could it be an injector O-ring?
Im racking my brain trying to find out what it is...
How can the FICM cause that much smoke? How do i test the FICU? Buzzed the injectors and then while running shut off the injectors 1 by 1 and they where fine....How do i test the FICU?
https://www.dieselbombers.com/ford-p...procedure.html
mine was starting hard, rough idle, LOTS of white smoke... it kept getting worse til i had NO power and eventually NO start!
Last edited by 03Powerstroke; Dec 10, 2011 at 06:48 PM. Reason: Automerged Doublepost
its fuel.. I pulled the voltage of the FICM and its 40v.
btw the 40v is on 12.5v bats. there are charging now. im starting to think that it is an injector.
