Vacuum pump??
Old Dec 8, 2011 | 06:56 PM
KillahExhale's Avatar
Question Vacuum pump??
have a boost issue, and have had so for a while. originally i thought it was the boost control selenoid at first. replaced that, all lines, and Wastegate. since vac pumps arnt so cheap these days, i was wondering if anyone had any idea if the vacuum pump could be the cultrip? would i be able to start/drive if the pump was shot?? could it also be the turbo itself is shot??
any help on this matter would be greatly appreciated, i would love to be bo0o0o0o0o0o0oo0stin"
Old Dec 8, 2011 | 11:06 PM
2MuchJunk's Avatar
Make sure you are getting vacuum to the solenoid. Start the truck and remove the line and check it. The truck will start and run fine with a bad pump or the lines broke.
Old Dec 9, 2011 | 10:52 AM
ebarresi5894's Avatar
..... or get a turbo master
Old Dec 12, 2011 | 09:52 PM
Crazy's Avatar
Default Reference material
So how do I know if my vacuum pump is working correctly?
You will need a vacuum gauge to properly test the pump itself. You will want to hook the gauge up as close to the pump as possible. You want to see at least 20”+ Hg of vacuum at Idle.
Do I have to hook directly up to the vacuum pump?
It is best if you do, however, you can test farther out on the on the vacuum system. You can check the vacuum at the soleniods, EGR, wastegate. This will help you determine if it is a bad device or a bad vacuum line if the vacuum pump tests good.
*Note: Testing after the solenoids may give a skewed reading as they regulate the amount of vacuum given to the devices.
My vacuum level is not very good?
If you are directly attached the gauge to the pump, and you have low or no vacuum, then your pump is bad. If testing further out on the system, you will need to connect directly to the pump to insure that you have no leaks in the lines between the gauge and the pump.
Are leaks common?
Very common. Leaks come from chaffing, hardened plastic lines cracking, etc... Sometimes the vacuum level may be okay, but if the engine rocks one side to another, it may open up a crack in the line and you will lose vacuum.
I don’t have a gauge, but I suspect I don’t have good vacuum. What do I do?
A real quick check of your vacuum system, which can be done at any time, is checking your waste gate actuator.
With the engine at idle, locate the turbo, and the can on the side that has the arm in it, should be drawn up inside. Pull on it, to see if you can pull it out. If you can, you don’t have sufficient vacuum. That is not to say that the pump is bad, but just an indicator that you vacuum level to the turbo portion is not enough. You will need to do further troubleshooting to determine what’s wrong. If it doesn't move then you most likely have enough vacuum at the wastegate.
My waste gate actuator failed the test, now what?
You will need to determine if the waste gate solenoid is bad, have a leak, or bad vacuum pump.
How do I determine if my waste gate solenoid is bad?
Check to see if you have vacuum BEFORE the solenoid. These solenoids will go bad after some time. The little ball inside of them will rust that actually opens and closes the vacuum to the actuator. It will get stuck not properly regulate the vacuum. It may get stuck “off” which means no vacuum gets to the actuator, it may get stuck “on” where it has full vacuum all the time. The last condition would create a DTC (computer code for over-boost).
How do I check to see if I have computer codes?
Depends upon if you have an OBD-I or OBD-II computer. 1996 and after are OBD-II and require a code reader, pre 96 you can check with a paperclip. Check the FAQ’s.
I have a code for my turbo, and EGR.
Coupled together these two codes indicate a vacuum problem. Both systems rely upon the vacuum system to work properly.
I have a heavy duty vehicle that does not have an EGR. My vacuum system is not working, what are my options?
If you have a 2500HD or 3500 truck, not equipped with an EGR system, you may opt to abandon your vacuum system, and use strictly a spring tension waste gate operator. Instead of using a vacuum system to hold the waste gate closed, you use spring tension. Once boost is built to it’s maximum allowable level, the waste gate blows open. The spring tension provides the proper pressure to maintain a safe boost level.
Can I get more boost out of my turbo with a spring type waste gate actuator?
Yes, but remember, there is a limitation here for the engine. You don’t want to be driving more than 12 psi of boost pressure into the engine with stock tuning, or more then 15 psi with an aftermarket tune.
Where can I get one of these spring type waste gate operators?
There are over the counter ones available from vendors, or you can opt to build you own (Check the FAQ’s). Other members have done so, and you can search to see what they have built. Search the term "Turbo Master."
*NOTE: If you install a Turbo Master, your computer will no longer be able to control boost levels.
I have an EGR system, can I fully abandon my vacuum system?
No, you will still need vacuum for your EGR to work properly.
You must still leave all your solenoids hooked up to the electrical system, because the computer is looking for feedback and a circuit to them. Without them connected, the computer will generate a DTC code. You can only remove the solenoids and EGR if you have an F code computer or an aftermarket tune that has EGR Delete on it.
What would keep me from abandoning the vacuum system?
If you have an EGR or your HVAC controls are vacuum operated.
If I abandon the vacuum system, can I remove my vacuum pump?
Yes, you can, this means that you will require a shorter serpentine belt. Members have reported that it needs to be 1 inch shorter than your original, you may want to do some further investigating to make sure on your own.
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
InheritedDiesel
Apr 17, 2015 07:20 PM
DeLuzGN
Mar 17, 2015 08:08 AM
